V5 beta Mar-28-2023 available now - ACIS fillets
11034.77 In reply to 11034.76
Hi blackboard,
> Oh thanks,i don't now why if i choice dark theme my viewport color stay white as
> default,i change color and its work
That will happen if you've set a custom viewport background color in a previous version.
You can reset it to follow the theme color under Options > View > Colors > Background color: "From theme".
> I have another question do you want add full acis possibilities or only fillets?
I'm also expecting to use it for Chamfer, Shell/Offset, and what is called "Direct modeling" functions like transforming an individual face and the surrounding faces extend to meet the edited face. That should be a good spot to wrap up v5 at that point.
Over a longer period I'll probably experiment with replacing other things like booleans.
