V5 beta Mar-28-2023 available now - ACIS fillets
11034.72 In reply to 11034.66
Hi Finema,
> Can you put a rounded bevel (0,15 mm) to this model in attachment ?
The maximum it will go is 0.04 units. To go larger the profile curves will need to be cleaned up some more to remove those tiny line segments that Pilou shows above.
I've attached a version that has those removed, it can now be filleted at your target 0.15 radius.
