Hi Death,
> On my version (latest beta) it doesn't show the LIBRARY option.
> What do I need to do to see it?
What do you have selected when you run the fillet command? If you have curves selected then you won't see it, if you have edges selected then you should see it.
Are you testing with a default install or are you applying customized UI? Are you possibly overwriting the regular fillet command with an older version?
> Also: I don't see any thumbnails in explorer (win 10)
Can you show a screenshot of an explorer window?
