V5 beta Mar-28-2023 available now - ACIS fillets
11034.102 In reply to 11034.101
Hi Psygorn,
> Second, is ACIS library used only for fillets?
Yes at the moment only for fillets, but once a few more kinks are worked out I expect to use it in some other areas as well like chamfer, shell and offset, and face editing.
> (sometimes when I use ACIS to do the fillets I get torn faces but MOI says the
> geometry is solid & when I do the fillet with Solids++ I don't get that torn face) it
> is not a big issue at all, I just wanted to ask you about it out of curiosity. :-)
Yes if it looks like the thing Pilou shows and it goes away if you save and reload the .3dm file then it's probably that same display mesher bug.
It seems that ACIS tends to create trimming boundaries that sometimes run across some kind of bug in the display mesher.
I haven't quite gotten that figured out yet,
For the time being when you run across it, just try saving it to a .3dm file and reload it back in again.
