"make2d" oddities
11025.1
MOI V.4 and V.5 Beta
The results from using the make2D script are giving me
some unexpected results. See attached screenshots.
sample-01 shows the vertical hidden lines are not fully
extending to the visible part of the hole. There are some
short line segments (I changed color to red) to fill the gap
though. I get the short visible (red) segments even if I
uncheck the "create hidden lines" option.
Sample-02 shows another problem. Again the script creates a
short little segment that is disconnected from the main curve.
Sample-03 shows the opposite side of the hole, but this time
the visible line goes too far. Sample-02 and -03 shows detail
of holes in the vertical leg seen in Sample-04.
Not sure if there are any settings to avoid those cases. Changing
the predefined resolution to a much smaller or bigger value does
not solve the problem. But to my understanding the resolution only
affects the smoothness of the curves?
Just wanted to mention that the above mentioned problems occure
no matter if I create my 2D geometry with "make2D", "make4views"
or by saving directly to pdf/ai? This is a consistent problem not
only related to the part shown.
