Unable to Boolean Subtract
11022.2 In reply to 11022.1
Hi Andy, it's a lot more difficult for booleans to handle things that have coincident or nearly coincident surface areas.
So for your cut piece it would be good for it to be 2mm thick with 1mm going down like you have now but the other side 1mm above rather than flush.
Does it work ok if you get it set up like that?
