Hi Marek, your settings are stored in a file named moi.ini so you will need to copy that file from your old PC to your new machine.
You can find where moi.ini is located by going to Options > General > "Edit .ini file" button.
A dialog box will popup that will tell you the location of the moi.ini file on each machine - that's where you will need to copy it from on the old machine and to copy to on the new machine.
Also if you have installed any plug-ins, copy those over as well, those are files that you would have installed in a "commands" folder in the same spot as moi.ini .
