Distorted edge appears on the cylinder
11014.1
Hi, I'm trying to create the following shape.
To create this shape, a cylinder with spheres at both ends is made to crawl across the surface of the object and Boolean.
I'm almost able to create the intended shape, but there is an artifact.
Now, I'm verifying each operation to find the cause of the artifact.
So I found a little strange phenomenon there, so let me ask you a question.
When a sphere is placed on the edge of the cylinder and joined, a distorted edge appears on the cylinder.
[Enlarge]
There is no problem with cylinders made with Extrude.
When the cylinder is made by Sweep, distorted edges appear.
My procedure requires the use of sweep. Does anyone have an answer?
MoI version4, windows7,
marzRX
