Nimble Nudge (Script)
11010.6 In reply to 11010.5
Hey Michael,
Thanks for the quick reply.
> I'm not sure if I'm understanding correctly, but it's possible for a command to register
> a shortcut key that will override any regular one while the command is running.
Sounds like what I want to do (maybe double check what I'm describing below first though)...
Essentially, I'd like to make a button in the Nimble Nudge command pane that adds all the keys to the moi.ini file at once. Boom, you're ready to use the nudge script without having to manually setup each key or copy and paste it all into the moi.ini file. Being able to check if any of my assigned keys are already being used would be perfect so I can alert the user of the conflicting keys and either accept to override them or let them change them first. If I could master that, I think I could do whatever I wanted with setting up this nudge script in a way that's the most user friendly. I'd even put the small/normal/large amounts directly into the scripts of the shortcut keys to avoid having users edit the NimbleNudge.js file directly. It can all happen through the parameters set in the shortcut keys.
...I hope that makes sense. Maybe there's a better way? Maybe I can read and overwrite the moi.ini file directly? ...maybe this is not feasible at all? Let me know your thoughts.
Thanks, man.
-- Cody
