Hey Pilou and Brian,
It's a bit complicated to setup. That's for sure (all nudge scripts typically are, that I've seen). At the very least, I think I can make a visual component that appears, like all other proper commands do. It would provide a pop-up to explain how to set up the shortcut keys and how the tool it works. That's a great idea! It would just stay open until you do another command though (not the pop-ups, just the command pane). That should be doable.
Michael, maybe you can provide a little insight for me... is it possible to add, modify and delete custom shortcut keys and associated scripts from my own script/command file in MoI version 3.0? I poked around the "Shortcuts.menu.htm" file and saw some promising things.
I've always wanted to make my own full-fledged commands so this is the kind of kick in the pants I need to find out that it's probably too hard and that I should pick a different hobby. ;-)
