Lag on large files (V4)
10978.2 In reply to 10978.1
Hi Skywolf95, there are some settings you can adjust to help with large files.
Before loading your heavy file, go to Options > View > Meshing parameters and set "Mesh angle" to a rougher angle like 25 or 35 degrees and uncheck "Add detail to inflections".
That will make for a rougher display mesh for drawing shaded surfaces, the default is fairly dense.
Also maybe uncheck "Display hidden lines".
