Trying to figure this out
10970.7 In reply to 10970.1
Hi Sven, Barry has the right solution above (thank you Barry). Just in case it's not clear it's done by creating this construction geometry -
A 57mm circle centered on the juncture point:
Offset these lines also by 57mm:
The intersection between the circle and the offset lines will yield the center of the arcs:
So then draw an arc from center point, put the center point onto that circle/offset line intersection, first point of arc at the juncture point and the last point at the snap point on the original lines.
EDITED: 27 Jan 2023 by MICHAEL GIBSON
