Hi Naxos, I definitely want to add a realtime preview for version 2, I think it will be feasible to do it as wireframe like you mention.
> also, please put a 2D text feature in the "curves" section ;-)
This one was kind of a tough one to plan - instead of having 2 different Text commands, I decided to have just one text command under Draw solid that has the option within it to create either Solids, Surfaces, or Curves.
I decided to put it under Draw solid since I think that it is most frequently used to create solids.
Sometimes I have to kind of "cheat" a litlte bit with organizing things to reduce the number of buttons in the UI.
