On using dimensions as guides
10948.7 In reply to 10948.6
Hi Pior,
> bypassing the offset of the dimension object away from the reference points, setting it automatically as 0) ?
There isn't currently any method set up to skip the offset in the regular command but it is possible to modify the command's script code to do that.
I've attached a version that does that.
> (I also wish it was possible to rotate an Aligned dimension after the fact by simply moving the point around
> like one can move the points of a line, but I don't think that's possible ? Of course regular rotate work so
> that's good enough obviously).
You can turn on points for a dimension by selecting it and using Edit > Show pts, but the point manipulation will sort of stretch things out while keeping the same orietnation. If you want to rotate it you would need to use the rotate command or rotate handle on the edit frame to do that.
