API issues moving windows
10946.10 In reply to 10946.9
Hi Joe,
> I can get `resize()` to work but not `move()`...
Is it possible that the coordinates you are giving to move() are not at a visible point on the desktop window? Maybe the y coordinate in particular is underneath the Mac top menu bar.
What happens if you try running this version:
var dlg = moi.ui.createDialog( '<html><body class="DialogBody"><div>testing...</div><moi:DialogClose/></body></html>', 'resizable,defaultWidth:350,defaultHeight:200' );
while ( dlg.waitForEvent() ){
    if ( dlg.event == "display" )
        break;
dlg.window.move( 100, 100 );
> In this example, `isModal ` means that it blocks interaction with MoI until it is dismissed (Qt::ApplicationModal).
You can do a modal dialog by calling dialog.window.doModal(); after moi.ui.createDialog(). That will call setWindowModality( Qt::WindowModal );
> Style control the layout and window type like Qt::Window, Qt::Dialog, Qt::Tool, Qt::Popup, etc. Allowing
> the FramelessWindowHint would be cool to do HUDs and overlays.
You can use var menu = moi.ui.showMenu() to create a Qt::Popup window with FramelessWindowHint instead of a dialog.
The options you can currently set for a dialog are:
resizable, fixedWidth, fixedHeight, defaultWidth, defaultHeight, and noCloseButton.
