thin tangent lines in illustration output
10937.8 In reply to 10937.6
I appreciate it Zooen!
Pilou: Max's script that you linked exports to STEP and then imports the STEP back in. For curves, that merges the curve segments together which means that extruding the curve will only have 1 seam. But, I don't think Max's script has any effect on surfaces or solids.
This plugin doesn't actually change geometry. It just assigns tangent edges to a new style and hides seam edges. It's basically automating what you would do if you selected tangent edges one at a time and assigned them to a style and if you then selected seam edges one at a time and did Edit > Hide.
- Peer
