What are your favorit fillet companion to Moi?
10928.1
I have been searching the forum and googling to find the ultimate companion to Moi that does the best fillets and has the fastest workflow out and into Moi. I couldn't find a thorough answer and there has probably been changes and limitations to different programs that make the choices not so obvious.
What are your favorite fillet companion and why?
My own experience is the following:
The best companion:
1. Fusion 360.
Fusion simply made the fastest, easiest and best fillet for my trial model.
I used an iges file for import in Fusion and exported in stp back to Moi.
There are some extra curve lines that wasnt there in the beginning.
Disadvantage: You get a personal free version but it can't be used commercially.
2. Onshape
This one was as good as fusion but it was annoying to import and download the changed model from the cloud.
Disadvantage: You can't use the free account commercially and everyone has access to your models.
3. 123 Design.
123 Design was almost as easy as Fusion but you had to select all edges one by one where as you could select faces more quickly in Fusion 360. The fillet in Fusion seemed to be better as well. In the attached version I had some problems with the corners that I didnt have when I tried initially. I dont know what went wrong.
I had also bad luck with every file type but sat-file type. The size of the model changes when using stp.
Disadvantage: You have to look around on the web to download the software because it's abandonware.
4. RS Designspark Mechanical
This one was tricky to get working. The program is free to download but Step-files are locked for edition and filleting. Moreover you can't export in a format that Moi can read. Before september 2022 you could by an expensive addon module to be able to export in Iges and Step but they changed that possibility - maybe due to too much overlapping with the very expensive other CAD program they make.
After a long time I found a youtube video to unlock the import step file and downloaded a python script to convert the rsdoc file to a sat-file that moi can read. The youtube video link is: https://www.youtube.com/watch?v=gethrB_T3Oo
and the file converter python file is: https://github.com/arekm/rsdoc-to-sat/blob/master/rsdoc-to-sat.py (you have to install python and then use CMD to run it).
The actual fillet was a little bit harder to make for me than in 123 Design but maybe that's due to the other workflow.
Disadvantage: Cumbersome workflow and a bit akward fillet process.
5. Viacad Pro
I could only get it to work with sat files. If I tried step or Iges I couldnt orbit or rotate the model. I dont know if it's a bug in Viacad Pro.
I couldn't get the fillet working unless I filleted one edge at a time. There was no way to adjust the fillet with arrows/sliders. You had to input numbers. I couldn't get the same amount of fillet on the outer edges on all sides. The size of the model changed when exported back to Moi and was very tiny.
Disadvantage: The program costs a few hundred $. The filleting was worse than the other programs and Viacad seemed buggy.
I tried Freecad also but couldn't get it to work and fillet the imported moi-model.
