On disambiguation of selection in wireframe view
10926.6 In reply to 10926.5
Hi Pior,
> Is there a markup code (CommandButton or MenuItem) for the "Edit ini file" button, to
> put it in the main UI ?
Yes, you can find the current button inside GeneralOptions.htm inside the ui folder. It's this part
that you would put on a button:
onclick="moi.settings.editIniFile();"
> - I think it would be useful to have the option for see-through lines to also apply to non selected
> objects. That way one would be able to see everything about a part assembly at a glance without
> the need to select anything.
It is already set up like that by default. If it isn't working like that for you, then you've probably modified a
setting in moi.ini. Look under [Hidden lines] HiddenLinesSelectedOnly=y
The default is HiddenLinesSelectedOnly=n
> - Also (and perhaps this is tweakable already), the see-through effect could benefit from having more
> contrast (here using continuous lines for the sake of the example, but darker dashes could work too).
> All optional of course.
You can adjust the opacity level in moi.ini under:
[Hidden lines]
HiddenLineOpacity=34
That can take a value from 0 to 255. You can also alter the line style under:
[Hidden lines]
HiddenLineStyle=Dashed
That can take one of "Solid", "Dotted", "Dashed", or "Long Dashed".
