Hi Pior, Merry Christmas!
> Which one in particular would allow the flashing to be re-enabled ?
Look under [Selection] DisableSelectionEdgeFlash, if you've modified it to DisableSelectionEdgeFlash=y set it back to the default DisableSelectionEdgeFlash=n and then you should see a reaction when you select a solid that has only edges being displayed.
> If anything I could see this being useful as a custom toggle, done through script and assigned to a
> custom button in the UI - so if that is possible I'd sure love to know how.
Currently that's not possible, it's only being read from moi.ini and it's not accessible to script. I'll set up access under moi.selection.disableSelectionEdgeFlash for the next release.
