Adjust after flow deform
10916.6 In reply to 10916.5
Hi Matadem,
> If I use the surface to surface flow it will take the needed shape but not the spacing/angle in between.
I didn't find the surfaces you mention here inside the file, so I'm not sure what you ran into here.
You can get different kinds of results depending on how the surface is constructed, here's an example,
constructing the surfaces here using Construct > Network:
