Adjust after flow deform
10916.5
Good day...still need some help here.
The curve to curve flow works good....as I do have a pattern in the rectangle and it does transform it the way I need.
The other option to draw the rectangle for the spacing works good also.
If I use the surface to surface flow it will take the needed shape but not the spacing/angle in between.
So I tought after the curve to curve flow to do a surface to surface to match the 2 curve line but I did not get what I was expecting.
I have attached what I am after....after the flow on the curve to try to match both sides of the curves as precisely as possible.
If it was just the rectangles I could just use it and draw what I need...but since there is a pattern inside this would be very difficult.
Is there a way to acomplish this?
Thank you.
Size: 218.7 KB, Downloaded: 25 times, Dimensions: 893x612px
