Adjust after flow deform
10916.2 In reply to 10916.1
Hi Matadem,
> What would be the best way to adjust after flowing the rectangles on a curve?
It would probably be best to adjust the shape before you do the flow, not after it.
You could do a surface-to-surface flow to apply a bulge but also it is not too difficult to draw in a bulge.
I did that in the attached example by drawing in a curve like this:
Mirror that, then draw in lines like this:
Then use Edit > Trim to cut all that up and use this as the base shape for your Flow:
