Adjust after flow deform
There is another method but much longer to have more curvy result near network method.
- do the median curve (iso or cmorph process)
- Use a array/curve on a base line with the median curve.
- fix the size of segments to be on the curves
- loft the segments to have the destination surface
You loft and offset your pieces next
The Show Pts gives this
Size: 41.2 KB, Downloaded: 14 times, Dimensions: 155x281px
