Find center of 2 curves
10913.5 In reply to 10913.3
> Another trick ;)
> Menu Transform / Array Curves 3 (objects) Points!
I don't think that trick will work, since Array curve will make exact copies of a base object that are moved and rotated along the path curve.
Array curve will not morph a curve's shape between 2 different shaped curves as being requested here.
