Generating hidden lines
10911.4 In reply to 10911.3
Hi Rudl,
> What preferences must I choose, that I just see the faces and edges of the visible bodies?
Turn off (uncheck) the options for "Generate outlines", "Generate silhouettes", and "Generate hidden lines".
That will leave just visible lines being generated, which are always generated. There is no checkbox for turning off visible lines like there are for the other optional types of lines.
If you're running into a problem where lines are bleeding through where they should be hidden it probably means your model is at a too large or too small scale. Try sizing your model so that it is something around 100 units across and not say 10000 units across. You can also try setting the "Canvas megapixel resolution" option to be higher like say 35 or 45.
