Hi Pior,
> FWIW I too have been having issues with deselection, as ctrl-drag (= rectangle marquee) never did it for me
> as far as I can remember - only regular ctrl-click does it.
That's true for version 4 but it's been improved in the current v5 beta.
 https://moi3d.com/wiki/V5Beta
quote:  Update selection - multiple select. If multiple select only with shift key is enabled don't clear selection if ctrl is down so that Ctrl+drag will still work as a deselection window. Fixes bug reported on the forum by Viewbyte here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10439.3
You can get the v5 beta at  https://moi3d.com/beta.htm .
> BTW, on a semi-related note : since I never really tried it before I had some playing around with
> "multiple selection : only with shift key" OFF - and while it is interesting, I feel like it conflicts with
> the way MOI lets one deselect things by clicking in the empty space. Because that means that
> someone who actually wants to select multiple things without having to press shift will very
> likely lose their selection if they work fast.
There is no conflict that I'm aware of. Clicking in empty space to deselect works the same whether Multiple selection =  "Only with Shift key" or Multiple selection = "Always".
The default is "Always" because one of the earliest design goals for MoI was to be able to do basic operations in it without needing to touch the keyboard at all. It's one of the things that gives MoI some of its unusual traits.
