Making a sheet metal pattern from a Truncated Cone
10908.2 In reply to 10908.1
Hi Gunter,
Your desired cone object has a thickness.
Back in 2017, unwrapping a cone, or frustum, was discussed, using the script UnwrapCone, or UnwrapCone2.
https://moi3d.com/forum/index.php?webtag=MOI&msg=8753.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=6175.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=6175.39
Your object has a "frustum_thickness" of ___ units.
The outer frustum can be unwrapped, to form "outer_planar" face.
The inner frustum can be unwrapped, to form "inner_planar" face", which is slightly smaller.
The slant seams of the inner and outer faces are parallel, so the top and bottom rings are at the same angle, and have the same "angleThickness".
If a normal to the outer face is drawn at the top, the top of the inner cone extends past the outer cone by "extendDistance", equal to the distance from where the normal intersects the inner cone, to the top of the inner cone.
At the bottom of the frustum, the outer core extends past the inner cone by the same amount, "extendDistance".
So align the "outer_planar" face with the "inner_planar" face, offset by "extendDistance", at the non-slantseam edges, at both the top and bottom edges.
Also, separate the two planar faces by the "frustum_thickness".
Connect pairs of the 8 outer corners with lines, and apply Planar. Join to solid thick planar object.
The above instructions should be checked out by doing the steps in MoI. An explanatory model should be done...
(I think that Flow could do some of the face conversions...?).
The influence of the ductility, or elasticity of the silver is ???
I am a little uncertain of the mechanics of physical conversion of a ribbon of silver, to a rolled surface. The planar cone model would work for spring steel, which has elasticity.
On the other hand, if a ribbon of steel is run through rollers, to make a curved ribbon, the outer surface stretches???
So maybe the silver should start out as an unwrapped cone, with rectangular edges, the same size as the inner unwrapped cone, and the outer unwrapped cone surface would stretch?
And the thickness would diminish?
ps, how are conical cookies made?
EDITED: 4 Dec 2022 by BEMFARMER
