Ugrinsky Rotor
10897.2 In reply to 10897.1
A few minor changes were made to outer edges of blades.
Created helix, times 4, extending down 70 mm, for a section. (60 degrees)
Six sections would reach 360 degrees.
For blade cross section profile, did a two_rail_sweep to two helices. Repeated for other blade.
To Do: two interlocking pins and sockets, axis, top, bottom.
ps Earlier, script ImportSTL was used to import the thingiverse .stl.
The 59,000plus triangles mostly imported, with some lost.
The very large file produced a moderately good looking rotor section, enough to check and get distances and angles.
Then deleted the .stl import. Too Big...
EDITED: 17 Nov 2022 by BEMFARMER
