Learning to create addon
10889.6 In reply to 10889.1
I would suggest you best option and easiest to ask questions and learn is to design a “Node” to do this with Max’s node editor.
You would spend your time to generate 1 box with a node, then changing the values would be a quick change and output result.
A couple guys here could probably help you get the node setup with just a little bit of information/explaination aboit you box…
