best practice for cleaning up a model question
10879.3 In reply to 10879.1
Hi John, there are a whole lot of little slivery surface pieces that you'll need to get rid of.
So for example I selected these surfaces by clicking on them, not by window select so as not to capture the slivers too, then hide:
All these things that look like curves are actually little slivery surfaces, basically surfaces that have all their surface areas trimmed away. You don't want to have these things in your model so they should be deleted.
Something that you're doing is generating a lot of these as a bad side effect, like maybe something that is trying to intersect 2 surfaces that are already sharing an edge. Usually it's best to use the Join command to glue together 2 surfaces that touch each other and not a boolean command because Join only glues together edges and doesn't try to intersect things and remove material like the booleans are focused on doing.
