Is this really possible?
10876.4 In reply to 10876.1
Hi Dana, yes that's the history function in MoI. You can set that one up by drawing in curves as shown, then select one set of the curves and run Construct > Boolean > Intersection, then select the other set.
A solid will be generated where the curves project out to and if you edit the curves the booleaned result will update.
The main limitation to the history function is that to recalculate a result the input objects that were used need to still be present in the model. So it won't work if you do the boolean with solids as the inputs instead of curves because with solids the original objects are deleted.
