curve project + extrude
10871.2 In reply to 10871.1
Hi Ulisses, you probably want to use Edit > Trim to cut the cylinder then select the face and extrude that rather than extruding a curve.
If you extrude a non-planar curve it won't have its ends capped automatically as you will get with planar curves but if you extrude a face or an individual surface that will get a cap by copying the base surface to the end of the extrusion.
Check out here for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3024.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=4010.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=3318.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=4791.13
