Flow Text onto Surface
10870.2 In reply to 10870.1
Hi Andy, curve to curve flow doesn't know anything about the surfaces. If you go from a straight line path mapping to another straight line path that's not going to produce any curvature in the result.
You could put in a plane underneath your text and use surface to surface flow or you could use curve to curve flow if you project a line onto your surface like this so that it has the curvature of the extrusion's shape instead of going in the straight line direction of the extruded top surface shape:
