Continuous surface with sharp edge in MoI only - Possible?
10865.8 In reply to 10865.7
If you can tolerate the bottom deviating from the original curve by some small amount (like 0.02 units) then you could do the cut like this instead and the bottom part should be smoother.
Getting the top to be smoother is probably going to be harder, the base surfaces have different surface normals at the point that they touch.
