Hi Matadem,
> I am setting up sheetcam software right now...
> However when drawing in metric size a rectangle of 121.4cm x 243,8cm and when I try to export
> a dfx file from Moi 3d it comes up too small when I import in sheetcam.
> Sheetcam has an option to import metric, inches and custom.
Can you please post an example file that is not working for you? Please post both the .3dm file and the .dxf file.
That way I can check a couple of things.
When MoI writes out a .dxf file, it sets the unit system in the $INSUNITS header variable and many programs will check there and use the units that are set there but not all programs do that.
Thanks, - Michael
