Hi Mik, the main problem is the offset - MoI's solid offset tool does not work well in cases where pieces need to be extended and intersected with each other.
The geometry that the offset produced has some bad corners in it now where edges are quite a ways off from each other instead of meeting up with a good tolererance:
So I'd recommend not to do the offset on the threads object.
