how to terminate a script
10847.7 In reply to 10847.6
Hi Peer,
> What does this do?
> // config: norepeat noautolaunch
The no autolaunch is for when a command set is launched. A "command set" is a group of commands like Draw curve > Lines is a command set that has 2 commands in it (Line, Polyline).
When you open a command set (like click on Draw curve > Lines), the last used command will automatically start unless it's marked with "noautolaunch" which should be set on a command that just does its action immediately like Boolean Union for example.
I think I'll set it up so that if an alert dialog is launched it will automatically clear out the Repeat checkbox to help avoid getting stuck like this.
