Move from
10845.16 In reply to 10845.15
Hi Burr, yes that's true you can use relative point entry for this too, typing in r100,0 (an x,y coordinate prefixed with the letter "r") instead of using distance constraint if you want.
You can use that on a second time with the Move command after having first placed the object to be moved onto the other object's reference point.
There is also a way you can use relative coordinates to do it in just one use of Move too. To do that type in r-100,0 (note negative x value for this particular case) before you pick the first point for the move, that will displace the actual picked base point to be 100 units to the left of your clicked base point.
That looks like this:
