Trouble creating an aerofoil surface with curves
10839.1
I'm having trouble creating an wing surface. I figured the best way to go about it was to create multiple curves representing the forward curvature of the aerofoil, as shown here:
I've been trying to derive a simple surface from this set of curves by adding supporting lines and using the network command, but it fails to calculate. Maybe I'm approaching this wrong?
Initially I just tried to sweep the aerofoil's profile across the curve, but this didn't give the desired effect. I settled for multiple curves, which would, in theory, allow me to taper the wing's profile towards the wingtips. If I *could* do it like this, the desired effect would be ideal.
You can find the .3dm attached here if you'd like to give this a try, any help would be appreciated.
