Fillet & Loft
10832.12 In reply to 10832.10
Hi krass,
> The question is - is it possible to form the same angle in MOI or is it not provided constructively?
You can in some cases enable the "Straight corners" option to inhibit the creation of corner juncture patches but it's not very reliable.
But in cases where it works it goes like this:
Having corner junctures enabled usually helps make fillets work better in MoI so if you need that type of control very often you should probably plan on exporting to a different app and then filleting there and then bring it back into MoI.
