PDF Export Options
10825.6 In reply to 10825.5
Hi Axel,
> would it be possible to include the pdf option menu in the export tab so that only the selected
> objects will be exported and not the whole file with all objects will be saved as a pdf?
You can use File > Export to write only the selected objects instead of everything:
That should work for all formats including PDF format.
