Image in image command
An Image file may be loaded into the MoI view from a bitmap image, PNG, JPEG, TIF, or BMP file.
More than one Image can be loaded. e.g. a 2D violin scroll image in front view, and a different 2D violin scroll image in right view.
If I load an image (or two) into MoI, and check the option to Embed image data in .3dm file, the image(s) are saved with the saved .3dm file.
Question 1: What data is saved? Where and how is it saved?
(textures?)
Question 2: If the .3dm with embedded image(s) is loaded into Rhino 7, can the Image be viewed? (No?)
Or can the image data be accessed in Rhino 7?
Question 3: If the source bitmap image is deleted from the computer, can the bitmap image be restored from the embedded image in the .3dm?
(Or if a .3dm with an embedded image is received from a 3rd party?)
Thank you,
I seem to have a lot of questions about Image :-)
I noticed that the image can be loaded (say beginning at Origin), in any of the 4 quadrants.
Wondered if the "Left Bottom Corner", normally at the origin, still located at the origin, for the image in the other 3 quadrants?
(Of course, if so, it would not longer be either left, or bottom...)
I did look up embedding textures in Rhino:
quote:
"Save texture" is an option good for sharing Rhino files with textures to other users on other machines - the textures are packed in the Rhino file and this cause a larger size. If the Rhino file is opened at an other machine than the textures are unpacked in the working directory.
I noticed that once embedded, re-saving the .3dm to a different name.3dm, also keeps the image embedded, even though the checkbox is not checked. (not worried about this) (There must be a flag?)
(The Image can be "removed" prior to saving to .3dm)
EDITED: 14 Aug 2022 by BEMFARMER
