perspective projection 2D onto 3D
10807.7 In reply to 10807.6
Hi Peer, ok I see now - I had previously thought the rays would start at the camera point and go forward. You may need them to be a little longer if they're starting behind the camera point. Also the factory system may not be expecting to have a factory call both calculate() and also be used with update()/commit() as well with the same factory.
Does the attached version work any better for you?
