converting parametric 2d curves and circles to polylines
10797.7 In reply to 10797.6
Hi Pior,
> Is there any way to have this is part of the export settings, so as to not have to
> tweak the ini each time ?
I'll see about adding it to the DXF export options dialog.
> Also, is there any way to perform this kind of conversion without having to even
> export/reimport at all (that is to say, getting to the result from within the work scene) ?
You could use the ReconstructCurve script that Brian wrote about above.
