converting parametric 2d curves and circles to polylines
10797.4 In reply to 10797.1
Hi pior, by default the DXF export will create a LINE, CIRCLE, or ARC entity in the exported DXF file if the curve in MoI matches those types.
You can disable that by a setting in moi.ini :
[DXF Export]
UseSimpleEntities=y
If you set UseSimpleEntities=n then it will write circles as polylines or splines depending on the "Write curves as:" option in the export dialog.
