converting parametric 2d curves and circles to polylines
10797.15 In reply to 10797.12
Hi Pior,
> [Edit] : Oh OK I think I get it now. If a part has corners made out of circle sections (that is to say,
> perfectly round fillet corners), this part will indeed export out as polyline when the exporter
> option is set to that *if* the whole thing is combined and connected.
If you have a curve that started out as a rectangle and then had corners filleted, then that whole curve is not a line, circle, arc, or polyline and so will not be processed as one of those entities, it will go through general curve handling.
If you use Edit > Separate to break the joined curve into separate smaller curves then you will have 4 lines and 4 arcs and so in that case if UseSimpleEntities=y it will write those out as LINE and ARC entities.
