V5 - Grip Frames
10785.2 In reply to 10785.1
Hi Alan,
> It does not appear possible to change the opacity of the unselected grip fames in the Theme options.
> An option to do this would be helpful with dark UI backgrounds .
Yes, currently it's not a part of the theme options but I'll take a look at adding it there. You can set it
globally in moi.ini by setting
[View]
EditFrameOpacity=45
It takes a value between 0 and 255.
> As an option, big ask, perhaps add some grip files with different colors too ?
The grip appearance will come from these bitmap files:
You can have a theme replace any of these files by having a new file with the same name inside the theme folder.
