How to make this solid?
10782.21 In reply to 10782.19
Hi Koi, so then to put on the top as a separate piece you do something like this - I made a taller version of the one rail sweep to have more material to work with, it looks a bit weird at top initially but it's ok that doesn't have any actual bunching or self intersections and it will be getting sliced off:
Set up a cross section and rail for the top cap something like this:
Sweep to make the top cap base surface, note that you want this to be a simple extended 4 sided surface so it can be a relaxed surface that you will trim instead of trying to force the initial surface shape directly to the ending boundary edge:
Offset cap surface since you're making a thin wall shape:
Trim surfaces with each other and join:
Apply a G2 fillet:
