How to make this solid?
10782.2 In reply to 10782.1
Hi Koi,
Using the initial curves/surfaces did not work.
Delete the initial surface.
First step was a rebuild of one of the long curves.
Offset the new long curve inwards by 3 mm
Revolve the two curves by 90 degrees.
Copy both of the new edges to make two curves there.
Place 3mm line at vertex and sweep each pair of inner and outer curves. (twice)
Join the 4 surfaces to solid.
Boolean yields only a joined surface, during one trial.
(Planar with two 3mm lines, could be used instead of sweep. Boolean does not give solid, but Join does.)
Some of the initial geometry must have been off by a bit?
Another permutation is to rebuild one of the long curves, and revolve it 90 degrees.
Shell the resulting surface 3mm inward.
Perform planar twice, and Boolean Union the 4 surfaces to a solid. (Or use join.)
In this case, the Boolean Union does make a solid.
EDITED: 23 Jul 2022 by BEMFARMER
