Selection script
1078.7 In reply to 1078.4
> Comment out the one that's currently being used and uncomment the one you
> want - there's one for .getPoints that might work for you.
That one will only grab the standalone "point objects", like the kind that you create under Draw curve / More / Point.
Currently there isn't any way to target "edit points" like the points that show up on a curve when you use Show pts on it. Right now an edit point just isn't set up as an individually targetable object type. Eventually I'll figure out some way to expose these to scripts.
